Overlapping Clips waveforms? Opacity?
COW Forums : Adobe Audition
Matt Campbell
on Aug 29, 2013 at 3:27:36 pm
When performing an edit on a audio track, such as music, is it possible to see both waveforms on a clip? Meaning, if both clips are on the same track, is it possible to see where the outgoing clip and incoming clip overlap? You could do this in Soundtrack Pro and it made trimming music tracks much easier being able to view both clips waveforms so you can match waveforms where they meet and make crossfading easier.
Currently in Audition CS6, when clips overlap they are opaque. Is there a way to make them transparent or lower their opacity for uses described above?
OSX 10.7.5 with a 3.39 Ghz Intel Core i7 on a built up Hackintosh
16 GB of RAM with OSX on SSD, (2) internal HDDs RAID'd 1 for project files and External RAID 5 for all project assets (media, GFX, stills, etc.)
Paul Neumann
Re: Overlapping Clips waveforms? Opacity?
on Aug 31, 2013 at 1:32:32 am
Not that I can find. I remember having that feature on another audio editor I used some years ago (not Soundtrack Pro). Now I'm just used to zooming in and visually matching the clips on separate tracks then moving it up.
