In Adobe Audition, why can't I adjust the volume line on the track anymore?
COW Forums : Adobe Audition
David Wolf
on Aug 7, 2013 at 2:47:56 am
I don't see a lock anywhere on the program that I can use to unlock it... this is weird, it's never happened to me before. This is what it looks like right now. I go over the line used to adjust volume levels, and it wont show up or act as editable.
Example
David Wolf
Re: In Adobe Audition, why can't I adjust the volume line on the track anymore?
on Aug 16, 2013 at 1:47:17 am
Nobody?
jim leo
on Oct 30, 2013 at 5:27:52 am
I am having the exact same problem. I have been trying everything but the volume levels just won't budge. I know that's not much of a help to you but at least you know your not the only person this is happening to.
If I get a solution I will post.
jim leo
on Dec 22, 2013 at 8:06:32 am
I was having the exact same problem. Here's the solution: Hold down the shift key when you open up Audition. That will reset things and you should be able to adjust the volume again. It worked for me,
Luke McManus
on Sep 17, 2014 at 11:00:33 am
This works! Thanks a million...
