Drawing a Blank......(how to)
COW Forums : Adobe Audition
Joel Evans
on Nov 12, 2012 at 5:01:16 pm
Is there a way I can import a Youtube clip into audition and extract the audio?
A couple of years ago I did it with a different program, but if possible would like to figure out how to do it with audition, then save in a format I can use in Premiere.
Thanks in advance for any help given.
Thank you for taking the time to post.
Camille Katz
Re: Drawing a Blank......(how to)
on Nov 19, 2012 at 10:05:45 pm
The way I extract just the audio from a video is probably not very professional but its rather easy and still sounds good.
just play the video on youtube and click the record button in audition.
you'll have to go first into your computers recording devices and select Stereo Mix so it records it without outside noise but like you'd hear it if you had earphones in.
then just record it and it should work.
i did that once for a song and it sounded pretty good.
hope it helps and there probably are far better ways to do this than i know. :)
© 2018 All Rights Reserved
