Audition CS5.5 won't play tracks
COW Forums : Adobe Audition
Brandt Wilson
on Aug 7, 2012 at 1:53:47 pm
I'm using Audition for the first time, so this may simply be user error.
After exporting a clip from PPro to Audition, the space bar and play button, while changing the state of the playback buttons' appearances, doesn't play back the audio.
As a follow-up, what I'm trying to do is remove some hiss that I believe is an artifact of the automatic gain control on my GH2. This is a live recording of a concert and there are no periods of silence that I can pull a sample from to perform an adaptive noise reduction on.
Any ideas?
Stefan Wiegand
Re: Audition CS5.5 won't play tracks
on Aug 7, 2012 at 2:56:22 pm
Does the playhead move when you hit space with the PPro clip open?
Do the track meters show anything?
Does Audition play other audio files?
Stefan
Adobe Premiere Pro Engineering
Brandt Wilson
on Aug 7, 2012 at 5:35:21 pm
Thanks Stefan.
I successfully opened another audio file, rather than exporting it from PPro. I was able to edit that file.
After that, I was able to export and edit the sequence from PPro. Not sure what was up. Maybe a stuck driver?
Anyway, crisis averted. I used parametric eq to manage the hiss.
Brandt
Daniel Hoover
on Sep 6, 2012 at 6:46:11 am
This might be too late to be of any use for the original poster, but for future Google searchers, I thought I'd share my solution.
I tried to export a Premiere CS6 sequence to Audition CS6 for editing using "Edit > Edit in Adobe Audition > Sequence" in Premiere. After Audition opened with all of my audio tracks from my video project, I pressed play. No sound would play, the playhead cursor didn't move, however the play button in Audition lit up green like it was trying to play.
This stumped me until I realized that Audition's audio hardware preferences weren't set to the proper audio driver. They were set to my default Windows audio driver and not my USB mixer than my speakers are plugged into.
I fixed this in Audition using the "Edit > Preferences > Audio Hardware" and choosing a different Default Output.
I hope that is helpful to someone! :)
Jason Sirotin
on Feb 5, 2013 at 4:32:33 am
Daniel, I just wanted to say thank you! You just saved me hours of trouble shooting. I am so thankful for people like you who are willing to take the time to solve other peoples problems. If you are ever in Atlanta I owe you a beer.
Steve LeMay
on Sep 27, 2014 at 3:19:39 am
I just wanted to interject.
I was having a similar problem. I would load a track for editing, but when I click the play button, the play button would light green but the transport wouldn't move. Having checked all my settings and sample rates, I turned my attention to the Master Clock and noticed it was set to 'In'. This means, it's waiting for a clock time-code signal on the audio input line to trigger playback. Since I don't have an external master clock, I set it to 'Out' making my computer the master clock.
This solved my problem and operation has been normal ever since.
Charles Thomas
on Nov 14, 2014 at 10:18:15 pm
Steve, thanks. It helped me out in a time crunch.
Aaron Davis
on Jul 22, 2015 at 1:59:53 pm
thanks so much Steve. The master in vs out was the issue for me as well...Strange thing, I've been editing for over a week with no problems...Then the parameters I set up changed all on their own after logging out and back into a session in both the master settings and the sampling rates. Was really weird. I didn't catch the master settings until seeing it on your post after working for an hour myself to try to figure it out. So thanks...
Steve LeMay
on Jul 22, 2015 at 4:34:38 pm
Glad to be of help.
Anna Fisher
on Dec 4, 2014 at 2:31:49 am
Thank you so much for posting!
I love that you came back to share the proper workflow.
fixed the same problem i was having :)
Chris Curtis
on Sep 5, 2016 at 9:26:25 am
Fantastic forward thinking! I had the same problem and your advice fixed it. Saved an awful lot of wasted time! Thanks!
Fridrik Skulasson
on Apr 13, 2017 at 9:07:53 pm
I stumbled upon this exact problem; I pressed "Play", either by clicking the button or by hitting Space, and the play button itself lit up and the meters went up to the appropriate level, but there was no movement of the transport bar, nor any sound. It all looked like the whole application had freezed. What's more, it all worked just fine and then suddenly just stopped working mid-session, as in you could do maybe 10 playbacks or something like that before it all ceased working. Only by rebooting the computer I could play it back again, only for it to fail after a handful of playbacks.
A lot of entries on various forums seemed to pinpoint the audio hardware selection being wrong but it didn't make any sense as it always started out working just fine, and the selected output hadn't changed either. After reading this thread, I started thinking that Audition maybe was confusing the audio devices. See, for recording I use an external device and for mere playback I often use the internal onboard device. In addition I also have another sound card installed but which I currently don't utilize for anything, which means it shows up in the audio preferences.
So I simply deleted all the inputs and outputs in the Control Panel sound preferences that had anything to do with this additional card, as well as disabling it in the Device Manager. This forced Audition to only concentrate on the onboard sound device and what do you know, that did the trick for me. It seems that Audition is easily confused with multiple devices so my two cents here would be to disable every sound device bar the one you will use with Audition.
