Not able to monitor while recording
COW Forums : Adobe Audition
Pattie Olson
on Jun 2, 2012 at 6:25:07 am
I am not able to monitor the narration while recording. Audition records and I can play that back and hear it just fine. Speakers work fine for playback and for other applications except there is nothing from them or my headphones while someone is recording on the mic. I'm missing a setting somewhere but can't figure it out.
I'm on win7 64 bit, Audition version is in the 5.5 bundle. Drivers are up to date.
I used to have an Alesis Firewire and it worked until it died, but now I just purchased a Grace m101 and a Presonus Firestudio mobile and have this glitch I'm trying to resolve.
I've gone into Audition's Audio Hardware and selected Asio Presonus Firestudio.
I've made sure the sound setting on the computer itself are also set for the Presonus and it is.
Any assistance would be appreciated.
Pattie
Steven Talley
Re: Not able to monitor while recording
on Jun 5, 2012 at 6:40:44 pm
In multitrack you enable Monitor Input. It's the button to the right of the Record button for each track. Use multitrack for this ability. Double click the recorder track to go into edit mode (stereo track mode).
Pattie Olson
on Jun 5, 2012 at 7:21:51 pm
Thanks Steven,
I should have returned to post here that I did get it after all. I am going thru the Lynda.com tutorials, and had activated the R, but overlooked to follow thru with the I.
I am still going thru the tutorials, but will probably have additional questions in the future as I climb thru the learning curve.
Thanks for your time and response, I appreciate it!
Pattie
