How do i "Extend" Duration of a track
COW Forums : Adobe Audition
Anna Poly
on Dec 2, 2009 at 3:56:21 pm
Hello all,
I would like your help on the following.
1. I have an audio clip which is 3.25 secs long. How can i "extend" the duration and make it 10, 20, 60 minutes long?
What i have done in Multitrack view:
is to enter a Split at 2 min then another one at 3 min (3 parts )==>copy and paste part2 multiple times till it reaches 20 minutes.
is this the correct procedure, or do you suggest another one.
2. i have a track with music and vocals, and i want to delete the vocals and use the music only.
I ve used the:
Center Channel Extractor==> Karaoki drop vocals 20db
Channel Mixer==> cut vocals
None of them worked.
Is there any way i can do that?
Gerry Bayne
Re: How do i "Extend" Duration of a track
on Dec 3, 2009 at 4:40:51 pm
Could you explain what the track you want to extend contains? Is it just something you want looped or
to just duplicate and have it repeat? There is a "duplicate track" if you right click the sound file in
multitrack view. You can repeat it as many times as you like.
© 2018 All Rights Reserved
