Keep voice, remove background noise and music
COW Forums : Adobe Audition
Ryan Moyer
on Jun 28, 2009 at 10:51:59 pm
I have a rather long video clip. At several points throughout the clip, there is some background noise and also some background music that occurs at the same time as someone speaking.
I would like to eliminate the background noise and music so I am left with ONLY the person's voice. When I run it through Adobe Audition 3 I can use favorites->vocal remover which perfectly removes the vocals and leaves the background noise/music. This is the opposite effect of what I'm looking for, but I figure if it can remove the vocals it must also be able to somehow give me just the vocals.
Is this possible?
Emmett Andrews
Re: Keep voice, remove background noise and music
on Jun 28, 2009 at 11:32:32 pm
Use the Center Channel Extractor. Using the standard channel mixer, it can't be done.
Ryan Moyer
on Jun 28, 2009 at 11:58:06 pm
The center channel extractor gives me the same result. It deletes JUST the voice and leaves everything else in. I want to leave the voice in and delete everything else.
I tried extracting all channels except the center individually (left, right, and surrounds) and it doesn't change the output at all. It sounds exactly the same as it did before editing.
Steven Talley
on Jun 30, 2009 at 3:05:44 am
In the CCE window select "Acapella" for the Effect Preset. Or you can try "Lift Vocals 10db"
Ryan Moyer
on Jul 1, 2009 at 3:23:34 pm
Unfortunately neither of those worked.
It seems pretty crazy to me, that there are 5 different ways I can remove the vocals without the background noise being affected at all but no way to just leave the vocals. Obviously the program can recognize the vocals since it has no problem deleting them so it should be able to separate them too. There's no way for it just to sort of extract them so I can paste them back in.
Ryan Moyer
on Jul 1, 2009 at 5:38:54 pm
Well, in case anyone comes across this in a google search a year from now, I guess I'll post up the half-solution I came up with.
In a few of the clips I was able to find sections where there was the background noise with no voice over it. I highlighted those sections, right-clicked and chose to use them as the pattern for noise reduction, and then chose (non-adaptive) noise reduction on the whole file. This worked perfectly on some of the clips, but on others where the background noise was less constant it would not work at all, obviously.
So at least I got some parts of it cleaned up.
China Sparrowess
on Jun 25, 2010 at 3:19:29 pm
Well, you know how you said "Incase one year from now, someone stumbles upon this on google, I'll post my semi solution."
Here's the thing. I'm looking to do the complete opposite of what you are doing. I have several clips from about 7 different movies, a short documentary, and a tv show with background music in which I fancy. I found your post extremely helpful, but before I go downloading anything to my computer, I'd like to know if you could help me out on a couple things. I take it since you have removed the background music out of some of your videos, you can do the same except instead of keeping the vocals and getting rid of the rest, you can keep the background music and get rid of the rest. I understand the analogy that you cannot "Unbake the Cake", However you can suck the filling out of a jelly donut without doing alot of damage to the pastry. I actually have been looking for a solution to my problem for over a year and I was wondering if you can help me.
Thank you so much in advance,
China
"Take what you can , Give nothing Back"
Ryan Moyer
on Jun 25, 2010 at 4:33:47 pm
I am a pretty novice user of Audition (I'm actually a video guy and just use Audition for some of the audio stuff when I don't have someone else to do it for me), however from my experience the route you're looking to go (remove vocals, keep background music) is much easier than the route I was looking to go (remove background music, keep vocals).
Audition has several presets for removing vocals from a track that work fairly well. It does not have any presets to remove everything EXCEPT vocals (which is what I was trying to do).
I don't have the program with me right now so I don't recall exactly where they are, but a quick google for adobe audition remove vocals should turn up lots of results.
As with everything though, your actual results are going to be very hit or miss dependent on the track you're using. Some tracks it can pull out the vocals without you even being able to tell they were ever there in the first place (rare), and some tracks it makes the thing sound worse than it did when the vocals were in there. Usually, it falls somewhere in between. If you've had trouble removing the vocals with other programs, I'm not sure that Audition is going to be able to do much better than them, though like I said, the presets do exist in the program.
China Sparrowess
on Jun 26, 2010 at 4:09:06 pm
Are you able to put the video file itself into Audition, or do you need to extract the audio file, as I've been told?
Ryan Moyer
on Jun 26, 2010 at 5:06:22 pm
I don't believe you can pull the whole video file in.
I was doing my editing work in Sony Vegas. From there I just set Audition as the default audio editor, then I could right click on the audio portion of my clip and I would be presented with "edit in adobe audition", which would open up the audio file in audition and any changes I saved there were automatically converted into my Sony Vegas project.
China Sparrowess
on Jul 4, 2010 at 12:41:51 am
Would it be smart to convert the video directly into an mp3 or should I use something like AV Video Morpher?
China Sparrowess
on Jul 21, 2010 at 3:26:33 pm
Okay,
I attempted to download and use the program Adobe Audition. Well found the channel extractor and the presets that you talked about, however, I only had the trial version of Audition and those commands were not available at that point. I'm not as financially equipped to buy that program right now, however when the time comes, I will buy it, but until then, do you know of any other programs that will do the commands that Adobe Audition wouldn't let me?
China Sparrowess
China Sparrowess
on Jun 25, 2010 at 4:05:17 pm
Well, I saw your post earlier on google. I happen to be looking for the same yet completely opposite of what you were looking for. I have some clips from about 7 moives, a mini documentary, and a tv show with nice background music in it. I saw your post, and I supposed since you found a way to get rid of everything except the voice in some clips, maybe you can help me get rid of everything except the background music. If you could, please tell me what program would work best (Adobe Audition Most Likely, what video file (WMv, avi, etc...) or audio file (Mp3, Wma, wtc) did u use and the process that would be best to remove the vocals and background noise. I have knowledge of the whole "You can't unbake a cake" anology, however "you can suck the filling out of a jelly donut without doing alot of damage". I actually have been looking for a solution to this problem for a little over a year. Please help me. Thanks in Advance,
China
Emmett Andrews
on Jul 4, 2009 at 2:17:09 pm
Audition doesn't recognize the voice. It finds and remove correlation between the two stereo channels. To properly isolate the vocals, there must be identical correlation in both channels on the vocals and zero correlation between the noise in each channel. As. you can imagine, that scenario isn't very common.
Emmett
Ryan Moyer
on Jul 5, 2009 at 10:47:19 pm
But that's the thing Emmett, it can remove the vocals while leaving the background music virtually unaffected, so obviously in THIS case whatever magical stars have aligned to make it such that Audition can distinguish between the vocals and the background noise. However, I can't figure out how to take that knowledge, and transfer it to only being left with the vocals rather than only being left with the background noise. Obviously audition can recognize the vocals because it can remove them no problem, but how can I then get to those vocals?
It would be like saying if I had a sentence on my computer screen that read "I like ducks because they look funny" and I wanted to separate the word "ducks", and the only thing I could do was end up with a sentence that said "I like because they look funny", but couldn't make a statement of just "ducks". Obviously I can recognize the word ducks in that sentence, so I can either remove that word or remove all the OTHER words. In my editing here, Audition can recognize the vocals because it can remove them, so there must be a way to also remove everything EXCEPT them, right?
Emmett Andrews
on Jul 6, 2009 at 12:54:36 am
As I said, no magic involved and it isn't recognizing the voice. It is recognizing correlated audio. There is enough of the background noise that is both correlated and uncorrelated that your ears are tricking you into thinking that it has been untouched. The fact is, you're removing a large amount of the background noise with any of the vocal removal tools. And the "a capella" preset is doing the exact opposite. It's leaving only the correlated audio. Everything you hear when you use that preset is exactly what's being removed when you use a vocal removal tool.
What you're trying to do does not work with your analogy. A much more correct analogy is that of trying to "unbake" a cake. Take a baked cake and get the eggs out of it. I dare you to try. A good scientist could remove and isolate large portions of egg product, but they certainly wouldn't resemble eggs anymore.
The Center Channel Extractor works better than most tools because it combines traditional polarity tricks with FFT processing. You can read about the basics of phase relationship here: http://en.wikipedia.org/wiki/Phase_cancellation
Emmett
George OConnell
on Aug 24, 2009 at 3:47:25 am
Emmett,
I am unfamiliar with the software, I found your question while searching for related information on Google.
You have at some point a track with voice, music, noise and a track with just noise and music. Add them as Left track and Right track in a sound editing program but add one of them as Invert and Mix. This should leave you with the noise and music reduced or eliminated. Hopefully this might help.
George
Stanley Dilley
on Nov 29, 2009 at 5:43:53 pm
I am 67 and find music and background noise on TV movies/shows drowning out voice. Therefore, I am also interested in removing or decreasing background sounds from voice. I have the following thought, please comment.
If a karaoke circuit can remove voice, inverting and adding the karaoke output to the original should leave the voice and delete or reduce the background sounds. It would need to be a stereo source with voice reasonably centered, which, I believe most TV sources are. I don't need complete removal of background, a reduction would be wonderful.
Jv Diaz
on Sep 8, 2013 at 4:08:59 pm
use center channel extractor.. keep the side levels at the lowest level maybe, and keep the center at below +10... but you can still here some background there...
robert romeo
on Aug 10, 2010 at 6:00:54 pm
Hi guys
Try this
Using Audacity
Step
1
Find a few seconds of audio that only contains the background noise you want to remove, and nothing else. You can usually find this sound at the beginning or end of the audio file.
Step
2
Find the selection tool in the Audacity tools tool bar (it looks like a letter I) and click on it. Using your mouse, click and drag over the selection of audio on the waveform audio file (WAV) that has only the background noise. Make use you only select the noise, and not any sounds you want to remain in the file when you are finished.
Step
3
Select "Effect" from the top menu, and then scroll down to "Noise Removal."
Step
4
Click on the "Get Noise Profile" button on the "Noise Removal" tool screen. It will use the selected piece of the file, and attempt to remove as much of this noise as possible.
Step
5
Select the entire file. You can do this by clicking "Ctrl-A," or by clicking with your mouse on the left-hand side of the WAV, beneath the name of the file. Select the entire WAV form.
Step
6
Go back and select "Effect/Noise Removal" again. You can change the settings, such as "Noise Reduction" and "Frequency Smoothing" using the sliders. You can click the "Preview" button to hear the differences. When you are satisfied, click the "OK" button.
Using Adobe Audition
Step
1
Select a section of noise that is at least half a second long.
Step
2
Select "Effects" from the top menu, and then scroll to "Restoration" and click on "Capture Noise Reduction Profile."
Step
3
Highlight the entire WAV from in the main screen to remove noise from the whole file.
Step
4
Select "Effects/Restoration/Noise Reduction." You can experiment with the settings until you are satisfied.
Step
5
Save your file.
Using GarageBand '09
Step
1
Import your file.
Step
2
Open the "Track Info Pane." Select the "Edit" tab and click the "Click here to add an effect" button.
Step
3
Select "Speech Enhancer" from the GarageBand effects menu.
Step
4
Select your microphone type and voice type (male, female) and the level of noise reduction you desire.
Step
5
Save and export your file.
Stanley Dilley
on Aug 10, 2010 at 10:30:07 pm
Thanks for replying. That should help with those dealing with a recording, but for removing background noise and music from TV for us old guys, its not a real solution.
Mark Keeler
on Aug 17, 2010 at 9:01:48 pm
Garage only works on a Mac doesn't it? Anyway I did watch one of the video's on YT with this approach, but the results were, to be honest, quite horrendous.
scott smolin
on Dec 21, 2010 at 3:22:52 am
In the past I used stereo equalizers to boost the mid frequencies that vocals are mostly on, and cut the high and low frequencies that noise and music are mostly on, of course this will not completely remove the noise and music just boost the vocals way above the noise and most of the music, with a PC usually theres vocal (for singing)
or speech(for speaking)preset EQ ssttings that do esentially the same thing.
Anyway this is probably the best that can be done since some of the music is actually in the same frequency range of the vocals you can't completely remove all the music without removing some of the vocals.
John Murrell
on Nov 7, 2011 at 10:57:36 am
You need to combine a number of tools to achieve this. It will probably not be possible to completely serperate the vocal. I use MAGIX Audio Restoration which I use for general audio restoration http://www.magix.com/us/audio-cleaning-lab/. I often use its tools to widen the stereo image, seperate the centre and side channels even further. I then use bx_solo(free) http://www.brainworx-music.de/en/download?PHPSESSID=aeogopu3v7kbu0e0efe495u... or some other tool to ms decode the sound (seperate the mid channel from the stereo). Not a perfect solution.
Ramtin Neydawood
on Dec 3, 2011 at 6:25:49 pm
Hi John,
I have a very important audio file that I needs some cleaning up. Judging from your posts, you really know what you're doing when it comes to this stuff. I was wondering if you would be willing to help me and I would gladly compensate you for your work. Please let me know...
Ramtin
tanja taxinapraxi
on Jan 23, 2012 at 9:41:06 am
hy Rian, did you find the solution about background? i'm searching the same thing... i have one skype call registrated where is the music in backgroung and i want to delete that music so i can hear the voice and conversation... so, did you find the program or the way how to do it? i would be so grateful if you can help me too. thanks in advance. bye. tanja
Ken Natan
on Sep 5, 2012 at 1:11:28 pm
I found a solution to this. (worked for me at least)
Quite simple and straight forward!
Download (free open source!) Audacity.
Load your audio file. (Video file didnt work for me, i had to convert it to an audio before I could process the file, in my case it was a vob file)
Once loaded, select the area you want to filter/extract voice of. (Sample it first, then get excited ... :))
Then go to Effects tab and scroll down until u see Low Pass filter. Play with the parameters and im sure you will have the solution there.
(I had bad noise on my wedding video which i wanted to get rid off and it seems to have done the job:))
Good luck
Roger Fevry
on Jun 30, 2015 at 9:28:14 pm
Hello!
I am new here, so I wonder if anybody could help me solve my problem ...
I have some nature documentaries with in the audio file:
- natural noises
- music
- a voice in Russian
_ and in the background the original voice in English
Now, my question is: could I remove the Russian (or lower it) and normalize the English?
Many thanks in advance ...
Roger
Lowell Niles
on Feb 7, 2016 at 5:28:07 pm
Hi! In reply to the original post: I looked at it for about 2 minutes and figured out how to isolate the vocals.
First, apply the "remove vocals" effect. After this is done, select the entire waveform and do "capture noise print". This sets everything EXCEPT vocals as noise. Then undo (command-Z on mac for example) the "remove vocals" effect so you're back with the original file. The captured noise print is still there, so now all you have to do is "noise reduction (process)".
Have a great day!
Lowell Niles
Creative Director, Sunword Studios
http://sunword.com
khan Roar
on Jul 31, 2016 at 12:05:01 pm
Here is few of video links which might help you
But before using these video techniques or tricks I would suggest try to upload video to your youtube account, and luckily it match with other video music then youtube will give you the option in copyright tab to remove the music below the video and also show you area where it match, press the remove song or music it will process the video viola the video has more music except vocals, it worked for me most of the time except few ones.
Good luck
P.S. I am newbie in audio extractor, so my comment is not 100% guarantee...
Ht Davis
on Aug 3, 2016 at 1:02:21 am
Does anybody else see it? If you can remove the vocals cleanly enough, output the file that way ("But but but..." STOW it and read on). Now you should have a file with vocal, and a file without. Split the tracks of both into mono. Phase one set and mix them together. At this point, your vocals should be back, with some noise left.
I'd suspect your problem has to do with mic distance, how hot, type of mic and\or how loud the person was speaking\singing. When this kind of thing happens, those are usually the culprits. When you have to fix it, note the following:
Is the noise as loud as your speaker or louder? Remove vocals, then phase to bring them back and work from there.
If the noise is softer than the vocals, option 1 works, but you can also resignal the whole thing. It's frowned upon in some circles, but it's saved my butt in several instances. ReSignal is an old cleanup method to get rid of amp noise or process noise. It works because it is an ELECTRICAL process, not a digital one.
Resignal makes use of the following standards for measure:
75% on any knob for volume is considered a 0 or no amplification, any above attenuates down, any above attenuates up, with most knobs attenuating +6 or +10 at 100%.
Most equipment will produce some noise when amplifying a signal, but not when de-amplifying it. Some equipment however, will still apply a resistance noise.
You'll need to know the zero points on your input equipment, have 2 DAW stations set up or 1 and another recorder with output capability. Resignalling requires enough time to play back the signal multiple times, and enough hard drive space to hold each pass multiplied by how many times you route back and forth. Explanation: To resignal, you'll output from one station, through an output card or box (xlr or TRS), something with a knob attenuated down from 75% to a bit lower, like 65 or 60%, out to the input of the other computer, attenuated to 75% or 0 adjustment. This track will output to the first computer again, from a device (amp IO box interface or mixer console) set at similar adjustment below 75%, with the first computer set the same way on the input (0 adjust). Most IO boxes have several inputs and outputs. IF you have stereo audio, you'll need 2 inputs for each send. This attenuates the actual signal you record and passes it back out at a slightly lower level. This smooths out the fundamentals and basic shake of the noise, so long as it's below the good audio far enough (a few dbv). The vocals can get to a point barely audible, and still produce enough signal to be useable. Just remember to offset the original track so it gives about 12-15 seconds of dead air you can use for noise printing. What to watch for: IF you can play the original or a a slightly lower volume track through a set of headphones while you are recording a pass, watch the meters on the other tracks (which should be connected to your other inputs)--the meter should move only when your vocals pass in or when the noise is just loud enough (you can attenuate by a smaller amount with a final pass), and the difficulty will be watching and working 2 screens at once. Once the noise is at a low enough level, we'll clean off the noise. Gather the 12-15 second front dead air, and combine it all into one sound, in its own track, save it to a file, open it up, select it, use the noise reduction plugin, capture and save the noise print. Open your final audio track you chose in file mode (not in multitrack editor anymore), run the noise reduction on it, but keep it between 80 and 95%. Now reverse the process you just did by amping the knobs by only a small amount, and use your new deamplified file as the starting point. Repeat the noise reduction process like before. Then do a new noise print on any remaining background noise. DOn't ask why, I just know it works.
Haley Mersh
on Apr 11, 2018 at 9:18:24 pm
I am having trouble trying to remove the background music of a video someone sent me taken on their iPhone. Is there anyone out there who wouldn’t mind me sending it to them and they have a go? I have gone through and tried most of the posts on here since 2009 and I feel I must give up soon before my fingers erode away lol!
Thanks Haley
Brian Code
on Jul 11, 2018 at 6:54:34 pm
Audionamix is a company that specializes is isolating dialogue and speech from background noise. IDC (Instant Dialogue Cleaner) is a new plugin that detects speech removes background ambience noise. There is a video on YouTube on that shows how it works:
