delay in output when recording AA3
COW Forums : Adobe Audition
dustin liggitt
on Jan 15, 2009 at 10:37:04 pm
i have adobe audtion 3 and i am trying to record a guitar with a delay but the soud coming from my monitors has a little delay to as well which is making it hard. its like when i strum the sound coming out is slightly behind. is there some setting i need to change? i am using XP and also the asio4all. i have tried changing the sample rate on asio4all but that didnt help. if anyone knows i would much appriciate it!
dustin
http://www.myspace.com/peroxidebase
Steven Talley
Re: delay in output when recording AA3
on Jan 21, 2009 at 2:44:47 pm
It's called latency, and it's there no matter what sound card/interface one might use. General use PC sound cards are worse for latency even when using ASIO4all. You could try changing the buffer size smaller to reduce the latency. lower is better.
Or get yourself a cheap USB interface such as a Fast Track or Toneport and the latency should be under 10 milliseconds.
