Effect transition
COW Forums : Adobe Audition
Heerko Groefsema
Effect transition
on Jan 11, 2008 at 1:23:00 pm
Hello,
A friend and I made this movie (beta version)
In the beginning I want the music to sound dampened, I used the effect FFT Filter with "The Club Downstairs" preset. When the camera goes through the car window I want the music to brighten up to its original sound.
The question is how to do a transition for an effect? What I have now is a hard break between effect and original. I want it to sort of fade the effect. Is this possible? And how?
I use Audition 2.0.
Thnx
Emmett
Re: Effect transition
on Jan 12, 2008 at 7:33:20 pm
Uncheck the box in the FFT filter that says "Lock to constant filter". Then you will have to set the initial graph and final graph (there are tabs for both). You will lose the ability to preview, so it may take some trial and error.
Emmett
Heerko Groefsema
on Jan 13, 2008 at 11:01:54 am
Thank you very much. I'll give that a try!
