Need a little help
COW Forums : Adobe Audition
Wolf 10
Need a little help
on Nov 10, 2007 at 1:34:25 pm
When I record something in one of the tracks it records fine, lets call this track 1. Now when I go to record in a different track that's at the same time as track 1 but in a different track of course, the track I'm currently recording just records the one from track 1 for some reason. Any ideas on how to fix this?
-Mike-
willie toth
Re: Need a little help
on Nov 10, 2007 at 3:29:47 pm
Mike,
What version are you using? Are you recording through a mixing board? If you are using a mixing board I think it is the likely source of your loop ... If you aren't then you have something set wrong in your track mixer causing the problem check for proper routing ... WILLIE
