Help. Session mutes some tracks, when using solo on others
COW Forums : Adobe Audition
Kovboy
on Aug 1, 2007 at 12:43:24 pm
This problem has happened to me in lots of other projects. Usually there's no way to fix it, as it follows the session-save-file.
Problem is this:
I play track A and B in a session. Then I fiddle with them both (effects and stuff). Then start listening to track B with the S (solo) button. Then I press the SOLO button OFF. Press play, and track A is STILL muted. To get the sound back on A, I need to push SOLO ON and OFF on track B. But this only works while the session is playing. As soon as I stop the playing, and start again, track A is muted again, no matter what SOLO-settings I have on track B.
This problem seems to follow the session-file (it
Kovboy
Re: Help. Session mutes some tracks, when using solo on others
on Aug 1, 2007 at 12:48:57 pm
It was a user error. It
Willie Toth
on Aug 1, 2007 at 12:55:06 pm
What version are you using? Sounds like it might be 2.0 ... I have not seen this problem before so I am a bit clueless here ... Have you tried to uninstall and reinstall? WILLIE
Kovboy
Problem fixed
on Aug 2, 2007 at 2:21:59 pm
As I stated in my second post on this subject, the problem is fixed.
It was a user error (my fault). I didn
