need some voices
COW Forums : Adobe Audition
cuboos
need some voices
on Jun 23, 2007 at 7:25:26 am
i need to know how to make a combine soldier (from half-life 2) voice
a dalek voice, and a menacing robot voice. any help would be appreciated.
ptrani
Re: need some voices
on Jun 25, 2007 at 5:49:45 am
When you say merge, you just want to play one after the other, right? You can use different tracks in Audition and have each one in it's own track. Or you can use Soundbooth and do the same thing. The beta is available on labs.adobe.com It's free and easy to use!
Paul Trani | Adobe Certified Expert
xgfmedia
on Jun 25, 2007 at 11:05:55 am
Dalek - http://en.wikipedia.org/wiki/Dalek
A third of the way down the screen, the modulation,
EQ, and sine wave tools which is mentioned in the
'Voices' paragraph, can all be found within Audition.
You'll probably need all 3 effects to pull it off
authentically, so consider it a good self-tutorial.
Robot Voice - Effects/Delay Effects/Echo/Robotic
This is will give you something metallic-sounding.
A start, at least.
Effects/Time_Pitch/Pitchbender/Up a Whole Step
Effects/Delay Effects/Sweeping Phaser
Effects/Filters/Dynamic EQ
- are just three of the ways to 'alienify' things.
Combine - Effects/Filters/FFT Filter/Telephone Filter
(or Voicemail)
These are walkie-talkie-sounding filters. Have fun
playing around with them.
Darren.
myspace.com/xgfmedia
Nick Wheeler
on Mar 8, 2011 at 2:23:15 am
XGFMedia: Really you don't even need the effects like that for the combine, for me it's just a hassle and the results are sometimes limited. You can use the View>Spectral Frequency Display select the middle (frequency selection tool "F")to find the area you are sure you want to keep, then delete the top and bottom of the selection until the desired radio/phone voice is acquired.
Nick Wheeler
on Oct 8, 2011 at 5:37:13 pm
Sorry I don't know why I forgot to add lowering the pitch apart from tempo. Then play with a few preset effects. I just got a perfect sounding combine. If you want I'll make a quick tutorial.
