remove hum
COW Forums : Adobe Audition
Trey Selman
remove hum
on Jun 21, 2007 at 2:47:23 pm
I have male voice speaking in a teaching session.
I have a hum around 121Hz.
Is it better to remove it with the Parametric Equalizer or to remove it with noise reduction.
I can do it either way I am just not sure what is the better solution.
If it is with the PEQ what should the Q value be (right now I have it set to 121.5 Hz -48db Q=2000) Is there a better way to deal with this hum?
Thanks for your help.
Willie Toth
Re: remove hum
on Jun 21, 2007 at 4:16:43 pm
I would use the noise removal but make sure you capture JUST THE HUM first ........... WILLIE
Trey Selman
Re: remove hum
on Jun 22, 2007 at 3:09:38 am
Thank you very much for your advice.
Trey Selman
