Audition 2.0 Scroll Bar length adjustment
COW Forums : Adobe Audition
peteinglastonbury
on May 14, 2007 at 5:56:09 pm
Is it possible to adjust the length of the scroll bar in Audition 2.0? I'm producing an audio play and the WAV file(s)I place on the Multitrack view time line contain all the actors' fluffs, re-takes etc. The scroll bar adjusts itself to the length of the furthest file end. Having edited the file it is perhaps a quarter the length or less (and thus the length of the project) but the scroll bar doesn't shorten to suit (as the yellow bar does in Premiere). So it's quite easy to end up with a tiny scroll bar when the whole project is set to fill the multitrack panel. It's not impossible to work with, but surely there must be a way to reset the length - if there is, I'm blowed if I can find out how from the Audition Help. Have I missed something obvious? I'd be very grateful if someone would answer me!
Pete
endrids
Re: Audition 2.0 Scroll Bar length adjustment
on May 16, 2007 at 8:17:26 am
I've often wondered that myself... It is hard to move clips around when the scroll bar is so minute and sensitive.
