Error message when opening specific session
COW Forums : Adobe Audition
nabskater
on Feb 15, 2007 at 7:38:43 am
Hey, I'm using Adobe Audition 2.0 and everything is working fine for the most part, except one session file will not open. It gets an error (screenshot- http://www.tabularasamusic.org/images/audition1.jpg ) and then once i choose continue, it says its opening the session (screenshot- http://www.tabularasamusic.org/images/audition2.jpg ) but never makes any progress and the cancel button is greyed out, and the whole program basically freezes. I was about 95% done with a final mix of a song, so i would really like to get this back! Any help is appriciated, thanks!
PS, i tried un and re-installing it about 3 times, and i tried to restore my system to a few days ago when it worked, but none of those worked. And other session files still work fine and open normally, so I assume there's somthing wrong with that session file.
willie toth
Re: Error message when opening specific session
on Feb 15, 2007 at 11:32:40 am
A Didge player, cool ... Yes, it's your session file that has a problem and I see from one of your photo's that didge 9 is missing ... Try to locate didge 9 and get it into the session folder ... Have you ever tried adding Native American Flute to your recordings ... WILLIE
diggum
on Feb 22, 2007 at 5:49:24 pm
Any chance you can forward the .SES file to sndbugs@adobe.com ? Don't worry about the WAV files, just the SES session file. You're getting a pretty specific error message, so we might be able to compare the session file against the code it's butting up against and determine what's going on.
Durin Gleaves
Adobe Audition
