Distortion removal
COW Forums : Adobe Audition
Skeeter
Distortion removal
on Nov 16, 2006 at 10:47:12 pm
Hey,
I've got some footage in which one of the talent is wearing a wirless mic. However, ocasionally i get crackle sounds from the connection.. whether he was too far away, loose wire, or low battery.. I'm not sure the cause.
Whats the best way to reduce or remove it other than cutting it out completely (along with the needed dialogue).
They are not long in durration.. in fact only a up to few frames long each.
thanks,
Skeets
willie toth
Re: Distortion removal
on Nov 17, 2006 at 2:38:25 am
Skeets,
Read up on the SPECTRAL VIEW it's the best way to go about it ... You will be using the single noise removal feature ..... WILLIE
