Equal Loudness To Your Ear
COW Forums : Adobe Audition
OlavNossum
on Nov 10, 2006 at 6:57:05 pm
Hello,
With thousands of songs in our music library there is no consistent volume from track to track. We would like to set up and leave play lists without having to babysit them for volume adjustments between songs.
Is there a script that can be added to batch processing that will make every tracks volume sound the same loudness to the ear? Does the RMS value need to be set to a constant (say -10db) for every song, or is there another way?
Once again, do you know of a way to make thousands of songs sound the same loudness without having to go through every song and doing it manually?
Thank you for you help in advance,
Olav
willie toth
Re: Equal Loudness To Your Ear
on Nov 11, 2006 at 3:11:04 pm
Olav,
To my knowlege the answer to your question is no, there isn't any setting in Audition that can do a mass normalization ... To do it right you really need to go through a tune at a time anyway since you may have to adjust clip volumes as well ........ WILLIE
OlavNossum
on Nov 12, 2006 at 4:47:11 am
Willie,
Thank you for your response and your knowledge. Is there a way to make all the songs have a SIMILAR loudness? Because of right now there are extreme differences in the volumes from track to track.
If it can
willie toth
on Nov 12, 2006 at 5:57:55 am
Olav,
No I don't know of one but as I said before the only real way is a track at a time because of the volume differences ... Sorry ... WILLIE
SteveT
on Feb 4, 2007 at 4:07:11 am
Check out MP3 Gain
http://mp3gain.sourceforge.net/
Panagiotis Kouvelis
on Jul 23, 2012 at 12:24:01 am
Hi there, I don't know if you found an answer to your issue, the new Audition has the match volume windows with the new ITU-BS1770-2 algorithm and the old one has the older "perceived loudness" preset for this kind of jobs.
Try also LMB from NuGen
http://www.nugenaudio.com/LMB_Loudness_batch_processor.php
the Leven One from Grimm Audio
http://www.grimmaudio.com/pro_software_levelone.htm
or the open source R128Gain
http://r128gain.sourceforge.net/
Cheers!
