Cutting Long Recording into 10 minute Tracks
COW Forums : Adobe Audition
MarkofCain
on May 4, 2006 at 1:41:52 am
I'm using Audtion 1.5.
I often record long lectures and then burn them out to CD or to an mp3 player for listening on the go. A single track of 60 minutes of recording has its drawbacks -- but taking the time to select and copy 10 minutes at a time into the CD Project gets old real quick.
Is there a way to automate setting a new track at every 10 minutes? Either in Edit View or CD Project View or Multitrack View?
ozpeter
Re: Cutting Long Recording into 10 minute Tracks
on May 4, 2006 at 2:45:45 am
No - but a freeware program called CueListTool has the facility within it.
willie toth
on May 4, 2006 at 10:35:01 am
You can't do it automatically, but you can do it manually on the session side ... Bring your clip in, cut it at each desired length, highlight that section then do a mixdown of the highlighted wave and save ... When you have done this to the whole lecture then just simply write a CD like you would a music CD using each section as a stand alone track .......... WILLIE
