removing vocals or the singer's voice in the background music
COW Forums : Adobe Audition
april salvador
on Mar 21, 2006 at 9:47:22 pm
hi, i really need a help here. Does anyone know how to remove the vocal or the singer's voice in the background music? because i only the background music and i'm just starting to learn adobe audition. i will extract the music from an audio cd. i'm very hopeful that someone can help me. thank you in advance and more power to you.
sincerely,
april
willie toth
Re: removing vocals or the singer's voice in the background music
on Mar 22, 2006 at 3:36:22 am
April,
As long as the singers voice is centered you can use the voice removal on the edit side of the program, there is a shortcut in the favorites tab ... If you need to fine tune it you go to EFFECTS > AMPLITUDE > CHANNEL MIXER > VOICE CUT ... I think you will find that it may affect the music as well .............. WILLIE
april salvador
on Mar 22, 2006 at 7:33:37 am
thank you much willie. i'll do it. again thank you:)
willie toth
on Mar 22, 2006 at 2:15:38 pm
April,
Good luck ......... WILLIE
