pitch problems with audition 2
COW Forums : Adobe Audition
on Mar 4, 2006 at 9:44:53 pm
having a serious problem here with audition 2, as it plays back with wrong pitch - its own sessions as well as the older version's sessions (yes, I did save them "as" audition2 as requested)
this happens in both in multitrack view and in edit view.
with older version sessions pitch seems very slow
with some sessions made with audition2 - pitch is way fast when playing back, although sometimes this does not happen, meaning problem is inconsistant.
I record 32 bit 44.1
mixdown 16 bit
Pentium 4, WINXP Soundcard: Echo / Gina24
plaese help
willie toth
Re: pitch problems with audition 2
on Mar 4, 2006 at 11:55:04 pm
Had the same problem when I imported a sessions from 1.5, but yet the mixdown of the session was fine ... After I did a mixdown the session played properly ... After that I decided to leave 1.5 on my computer and if I needed to work on a session that was created in 1.5 I would just use 1.5 ... I haven't had a pitch problem with sessions created in 2.0 as of yet ........... WILLIE
© 2018 All Rights Reserved
