Pitch change
COW Forums : Adobe Audition
JPID-FLORIDA
Pitch change
on Jan 25, 2006 at 2:01:25 pm
Frequently after recording, the playback will be at a slower speed. Is this a problem with my PC or with Audition? Thanks.
willie toth
Re: Pitch change
on Jan 25, 2006 at 2:46:32 pm
What is your sample rate set to ... What kind of system do you have? What version of Audition are you using? Is this in the multi track view or edit view ... Does your mixdown play OK? WILLIE
JPID-FLORIDA
Re: Pitch change
on Jan 25, 2006 at 2:50:46 pm
I use 192 or 128. I'm almost certain that the PC is at fault and not Audition.
I have XP home OS, 1 gig ram.
Jim
willie toth
Re: Pitch change
on Jan 25, 2006 at 5:14:00 pm
Jim,
I would use a 441K sample rate at 32 bit for recording ... Micdowns of course should be 16 bit ........... WILLIE
incidental poet
Michael webb
Re: Pitch change
on Jan 26, 2006 at 6:02:55 pm
i'm having a similar problem we record in 48k to use in prem pro. when we import it in it reports and plays back at 44.1
Michael Webb
Training / Support
Apple Certified Technician Digital Video / Xsan for Video
Microsearch, Houston Texas
713-988-2818
Michael Webb
Editor/Videographer
Post Squared
willie toth
Re: Pitch change
on Jan 26, 2006 at 7:54:44 pm
Check to see what you your settings are for your mixdowns ...
