Clipboard doesn't seem to work!
COW Forums : Adobe Audition
stylz
on Jan 14, 2006 at 10:28:34 am
Might be real simple, when I try to copy audio from P.Pro to audition(using copy and paste) I get "No valid audio file in clipboard". Yes I set audition clipboard to "windows clipboard" still a no go. Any remedies?
Thanks in advance.
willie toth
Re: Clipboard doesn't seem to work!
on Jan 14, 2006 at 2:30:07 pm
You have to EXPORT AUDIO out of Pre pro you can't just copy and paste it ... Once you fix what you want to fix you need to save the changes and then replace the old audio with the corrected clip ... The new clip will sync up as long as you keep the same start point as the original clip ............ WILLIE
Stylz
on Jan 15, 2006 at 9:19:52 am
wow thats not intergration. Anywho might as well just open audio from video in audition.
