how to loop for background noise
COW Forums : Adobe Audition
jack halsey
on Jan 1, 2006 at 8:49:21 pm
Hello
I have a bowling alley scene and I want to add in background of a bowling alley..I have the sound clip but its woefully short..how do I make it into a loop for the duration of the scene?
willie toth
Re: how to loop for background noise
on Jan 1, 2006 at 10:45:32 pm
Jack,
There are two ways you can do this, the easiest, but sometimes not the best way, is to right click on the track and go to LOOP PROPERTIES ... In the upper left corner of the properties page you will see a small box that says ENABLE LOOPING, left click in the box and hit OK ... Now if you go to the lower right hand corner of the clip LEFT CLICK & HOLD while draging to the right it will loop your clip for you ... Drag until you get the legnth you want ... Make sure that the begining and the end of the original track starts and stops where you want all the tracks to start and stop from ... With this being background noise I would say that this is the best method to use ........... WILLIE
