working with Premiere 6.5
COW Forums : Adobe Audition
visualizer
on Nov 9, 2005 at 9:41:00 pm
How can I import my audio files from my Premiere 6.5 project. Will the project retain sync?
willie toth
Re: working with Premiere 6.5
on Nov 9, 2005 at 11:17:08 pm
You should be able to export just the audio and as long as you have the audio file starting from the zero point when you export it will sync up when you import the corrected wave file ... The other way is to go to IMPORT > VIDEO and import the clip you want to correct the audio into Audition making sure that the clip is an AVI file,then you can edit your audio, right click on the video portion of the clip and export with the corrected audio ... Reference the help file and it will run you through step by step ... WILLIE
incidental poet
