Converting .AMR files
COW Forums : Adobe Audition
Tim
by
on Sep 20, 2005 at 7:10:49 pm
I've got some recordings from a digital dictaphone that are .AMR format. Audition doesn't read them or interperate them. They will play in Quicktime though. Any ideas?
Tim
willie toth
Re: Converting .AMR files
on Sep 20, 2005 at 8:20:02 pm
Did you try to rename them? Can you record from the dictaphone to the computer, that certainly would be the easiest way ... WILLIE
Ozpeter
on Sep 21, 2005 at 12:15:24 am
Google turns up several converters from amr to wav - eg http://www.gromkov.com/faq/faq2004-0087.html
Tim
by
on Sep 22, 2005 at 6:24:27 pm
I've found that i can play the files in Quicktime and hit record in Audition and it will record in real time which seems okay. I'll look up the converter suggested.
Tim
