Help removing vocals??
COW Forums : Adobe Audition
Ron Mart
on Jul 21, 2005 at 4:44:02 pm
I've searched the posts and have not really found what I'm looking for.
I have a good audio track with a good beat but there are a few small section with some vocals that just don't fit for what I want. I need to figure out how to reomve these vocals.
willie toth
Re: Help removing vocals??
on Jul 21, 2005 at 6:19:09 pm
Ron,
Audition does have a filter for voice removal, however I haven't really tried it and don't know how effective it is ... I am at work and don't have the program in front of me and am brain farting on it's location ... Go to the effects tab and look for it in noise removal ... If you can't find it look in the help file .......... WILLIE
Ozpeter
on Jul 22, 2005 at 1:35:11 am
You want the Centre Channel Extractor in the Filters menu (introduced in Audition 1.5) which will either remove vocals quite effectively from the centre while leaving the stereo image intact - which is the big advance from the "traditional" methods - or it will leave the vocal and remove everything else, which is a totally new trick. It's not perfect however - results depend on material, and some phasiness can result - but it's probably ahead of any other solution unless you spend a fortune.
Ron Mart
on Jul 22, 2005 at 7:08:08 pm
Sounds like this will work. There isn't really much vocals in the song and I'd be happy with just greatly reduced levels of the vocals that are there.
