Remove echo?
COW Forums : Adobe Audition
Max Johnson
Remove echo?
on Jul 20, 2005 at 8:19:42 pm
New to Audition and I now need to remove a slight echo in a voice-over file?
Any ideas?
- Max
Max Johnson
Slingblade Digital
max@slingblade.com
http://www.slingblade.com/
DVD Menus and Authoring | Web Design | Flash Animation | Graphic Design | Avid Editing | After Effects | Video Encoding | Print Media
willie toth
Re: Remove echo?
on Jul 21, 2005 at 12:56:46 am
Max,
Echo is almost impossable to remove ... The best thing that you can do is try and EQ and compress to try and put it into the background ... If you like you could E-mail a couple minute clip to me and I can see if I can come up with a workable solution ... If you chose to do so you can E-mail it to loganonestudio@aol.com ... I can't say I can help but I will certainly give it a try ... WILLIE
