Mackie Onyx
COW Forums : Adobe Audition
Bill Skinner
Mackie Onyx
on May 12, 2005 at 4:54:48 am
Has anyone had success with the firewire interface with a Mackie Onyx board.
willie toth
Re: Mackie Onyx
on May 12, 2005 at 1:31:12 pm
Bill,
You may have to use the "rewire" feature but it should interface without problem ... Personally I am not a fan of the "Makie sound" but I don't do a lot of driving rock either ... How many channels are you recording at once? I am assuming that you are thinking of purchasing a board plus the interface ... Presounus makes a firewire unit called the "firepod" that has 8 in's ... There are a lot of options out there depending upon your use ... The Mackie unit is well rated on Americanmusical.com ... Hope this helps more than confuses ....... WILLIE
Ron Moody
Re: Mackie Onyx
on Jun 22, 2005 at 3:30:22 am
It was pretty much plug-and-play. I didn't end up doing the final recording, but did do several test recordings and it worked. OK, it MOSTLY worked (once it crashed but every other time it worked.) I assume it was Audition that caused the crash but don't know for sure.
I was using the 16 channel Onyx and it sounded pretty clean to me.
ron
