How do you remove Heart Beat from speech wav
COW Forums : Adobe Audition
Clif Willard
on May 5, 2005 at 3:12:26 am
Hi All,
I have a tape that was recorded with a lavelere mic. The mic was clipped to the man's shirt so you can hear his heart beat throughout his speech. How can I remove the heart beat? I tried the equalizers and noise reduction but no luck. Any suggestions?
Audition 1.5
Clif
Clif Willard
NON ILLIGITIMI CARBORDUM
Steven L. Gotz
Re: How do you remove Heart Beat from speech wav
on May 5, 2005 at 4:55:54 am
Clif,
I believe the phrase is Non Illegitimi Carborundum
Getting rid of the heartbeat might be a good use of the Spectral View that Willie has mentioned a few times lately.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro http://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 http://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
Clif Willard
on May 9, 2005 at 3:34:13 am
Oops, thanks for the correction. I am trying Spectral view. I will let you know.
Clif
Clif Willard
NON ILLIGITIMI CARBORUNDUM
willie toth
on May 5, 2005 at 11:05:31 am
Clif,
One thing to watch for, if you are getting a heart beat your gain much have really been up, or it was a combination of gain and placement ... It will be a lot of work to remove it because you have to do each beat individually, but I think the only way is using the spectral view ... The problem we run across is that the voice might be degraded by using the spectral view ... Let us know the outcome ... It might be easier if you could shoot it over ...
Willie
