Trails and TimeAverage don't render
COW Forums : Genarts Sapphire
Nenad Kraljic
on Dec 15, 2010 at 1:34:46 pm
Hi, I have a problem with the sapphire Time filters in AE CS4, as they won't render when I hit "make movie"! In RAM preview they work as they should, but I can't render the whole preview from RAM because I run out of memory.
Gary Oberbrunner
Re: Trails and TimeAverage don't render
on Dec 16, 2010 at 1:30:05 pm
Hi Nenad; I suggest you contact GenArts support; they can help figure out what's going on. Those two effects do have to be rendered "in order" (one frame after the other), or they don't give correct results, which may be what's going on. You can submit a support request from our form at http://www.genarts.com/webforms/genarts-support-form.
-- Gary
