transition problem
COW Forums : Genarts Sapphire
Paul Thomsen
transition problem
on Sep 27, 2010 at 3:55:06 am
Gday just trying this out and having issues doing transitions in Premiere CS5. Worked out how to keyframe the transition on different video tracks after initial confusion after I realised it doesn't work as normal transitions.. but... if the transition is going to a clip with another effect on it - such as mercalli stabiliser... i notice that the transition uses the original source of the clip (eg non stabilized) for itself which produces a jump to the modified clip footage when the transition is over...
