Edge Rays on text disappearing when over white background - Gary?!
COW Forums : Genarts Sapphire
Alex Bond
on Dec 4, 2009 at 1:45:47 pm
Hi there,
I am trying to add edge rays to text, I've done this successfully in the past but when I add a white background the rays vanish - any ideas?
V2 Text in Title tool with Edge Rays applied (Blue text, blue rays)
V1 White Background
To create the White background I've tried using Title tool to make a separate layer, I've tried adding a white background within the text layer itself and I've tried creating a white title tool graphic and video mixdown to create (effectively) a piece of footage.
Any ideas?
Gary Oberbrunner
Re: Edge Rays on text disappearing when over white background - Gary?!
on Dec 4, 2009 at 7:54:13 pm
Hi Alex. Rays normally add luminance (brightness) to the background; they have no opacity of their own. So if you add blue rays to a white background, you get... white. (It may be super-bright in the blue channel, but still white).
But, you can turn up the Affect Alpha parameter to make the rays partially opaque; then instead of adding they'll composite over the background (depending on how much alpha you add). Hopefully that will give you the look you're interested in.
-- Gary
Alex Bond
on Dec 7, 2009 at 3:40:44 pm
Cool, thanks again Gary
A.
