Upgrading from DSv8 to DSv10 - Ramifications?
COW Forums : Genarts Sapphire
Jeff Winston
on May 14, 2009 at 5:43:35 am
In order to upgrade my Avid DSv8 to DSv10, what will I need to do to make sure my Sapphires are compatible?
Jwinston
Jeff Winston
Gary Oberbrunner
Re: Upgrading from DSv8 to DSv10 - Ramifications?
on May 16, 2009 at 8:49:19 pm
Hi Jeff; Sapphire should just continue to work if you upgrade to DS10. If you reinstall the system, you'll need to reinstall Sapphire of course.
-- Gary
Jeff Winston
on May 20, 2009 at 6:31:14 am
Thanks. I should have been more precise. The concern was that since we were moving to a 64 bit OS we might need to budget for an upgrade?
Jeff Winston
Gary Oberbrunner
on May 21, 2009 at 12:35:19 pm
Hi Jeff. As long as you have v2 (2.081, make sure you install the 64 bit version) or v3 (32 and 64 bits in the same installer) you should be OK. See http://www.genarts.com/support/sapphire/avid#ds. V1 will not work on a 64-bit OS, it's too old.
-- Gary
