Apply Sapphire Light Rays to specific areas of the frame
COW Forums : Genarts Sapphire
Alex Bond
on May 5, 2009 at 11:51:26 am
I am trying to apply a Sapphire Light Ray effect to a shot but I don't want it to affect the whole of the frame so I need to mask of some areas - I can't quite work out how to do this, I can see the Mask option on the effect but how do I acutally DO it?
Cheers
Alex
Avid Media Composer with Sapphire plugins
1 Layer of Vision on V1
Gary Oberbrunner
Re: Apply Sapphire Light Rays to specific areas of the frame
on May 5, 2009 at 1:11:24 pm
Hi Alex; just paint or import a mask clip with the area you're interested in (or use a Sapphire effect or whatever you like), put that mask on another layer below the layer of interest, then in Rays select Mask Use: 1 Track Below. Rays will only come out of the areas where the mask layer is white. (You can switch it to use black if you like.)
Hope that helps;
-- Gary
Alex Bond
on May 5, 2009 at 2:17:52 pm
Cheers Gary, will have a go at this when I get my edit suite back!
