Glow with Animated Matte over Video
COW Forums : Genarts Sapphire
Mitchell Jacobson
on Oct 15, 2007 at 3:38:26 pm
Hi There! This is my first post to this forum. I searched for question and found parts of the answer that were helpful but, not the complete solution.
I would like to use the glow effect on text with the animated matte and key that over a video background.
I can get the effect to work with the text and the animated matte but, I can't get it to work over video...just black. I've tried various combinations ie: not applied to key: background 2 tracks below, etc...I even tried stepping in and replacing the title mat withthe animated matte.
Here is how the parameters are set:
V3 Text w/ glow, applied to key; no background; mask on track below
V2 Animated matte (works as a title key or pict)
V1 Stock footage (Does not show up)
Is this possible???
Mitch Jacobson
Producer/Editor Avid & FCP
New York City
Todd Prives
Re: Glow with Animated Matte over Video
on Oct 15, 2007 at 7:50:23 pm
Hi Mitchell,
Since Avid doesn't process Alpha properly when working with effect, there is a bit of different thinking involved when it comes to doing this.
V3 title
V2 animated matte
V1 background
place your Sapphire Plug-in on V3 open the effect editor and click the Apply to Title/Key checkbox. Set the Background: None and set Mask: 1 Track Below. Now Alt+Drop S2_Layer (in the Composite family of effects) on your V3 title, make sure the Background: 2 Tracks Below and Mode:Normal
A more in depth example of this with projects is available with our training guide:
http://www.genarts.com/training-guide-avid.html
Regards,
Todd
Mitchell Jacobson
on Oct 15, 2007 at 8:08:36 pm
Thanks, Todd!!
This worked like a charm...much better than my workaround of mixing down the effect, creating a matte than keying that over footage....perfect. Thanks again...
Mitch Jacobson
New York City
Jesse Adlin
on Mar 14, 2010 at 12:02:21 am
I've always had a problem with sapphire an avid. When I follow these direction the title created in title tool disappears. What can I do?
Thanks.
