Full Width Navigation Bar Problems
COW Forums : Web Design (Wordpress, Joomla, etc.)
jamie wilson
on Jan 15, 2013 at 6:58:59 pm
I have had a problem with making this nav bar 100% width for ages. I'm not sure if the problem lies with the nav.bar container or the header.container.
I was hoping some pro could take a look at my website and give me a hand. I have spent weeks on this 1 part so I don't expect a reply or any help but if you do I will be in debt to you FOREVER!
Light Evolution - LED Lighting
I'm not sure if that works ^
So http://www.lightevolution.co.uk
Any and all help is appreciated,
Matt Geier
Re: Full Width Navigation Bar Problems
on Jan 15, 2013 at 8:05:00 pm
Hi Jamie.
Thanks for posting.
I've looked at the link and I don't particularly see the issue.
I appeared, normal.
Can you specify what you've seen as the problem..
Might also be helpful to know what broswer your running / have tested with.
Matt Geier
(Video Networking Solutions Expert)
(Creative Design Workflow Consultant)
(Social Media Networks Consultant)
(Technical Video Industry Sales Consultant)
demetri tashie
on Jan 15, 2013 at 8:17:26 pm
you need to work with/target either the li or the a element and change some settings.
you could for instance give each list element a fixed width, or you could increase/play with the padding or margins.
here is one way, which increases the padding of each a element inside the list element from 0.5em to 3.0em:
#navMain ul li a {text-decoration: none;padding: 0em <b>3.0em</b><i></i>;margin: 0;color: #fffffd;white-space: nowrap;}
play around with that and see what you come up with.
there are many other ways to accomplish this also. this is just one way.
you can take a look at this pared down file here if that helps:
5234_nav.html.zip
