AJAX to PHP return code.
COW Forums : Web Design (Wordpress, Joomla, etc.)
Lauren Brogan
on Nov 21, 2012 at 3:14:49 am
I'm just getting into coding with AJAX and am having a bit of trouble figuring out how to use AJAX code that returns content from a PHP file. I basically need it to pass in a page name and have the PHP load the contents of the page, then return to the client, then place in a DIV. Any help would be greatly appreciated.
demetri tashie
Re: AJAX to PHP return code.
on Nov 23, 2012 at 3:15:14 am
if you work through these simple tutorials, you should get a good understanding of using AJAX to dynamically load contnet: http://www.w3schools.com/ajax/default.asp
they go through step by step how to get your AJAX xml httprequests to work
