Changing Fonts (and related settings ) In Wordpress
COW Forums : Web Design (Wordpress, Joomla, etc.)
James todd
on Oct 25, 2011 at 5:33:06 pm
I am using wordpress for my blog/site. I am using Freshnews theme from woothemes as the theme for the blog.
Here is the link:
http://demo.woothemes.com/freshnews/
The font is not that good and it is way too small and the spacing is bad (too congested).
How do I change the fonts, size, spacing (line and paragraph) throughout the blog.
I know I would have to change it somewhere in the stylesheet. But where exactly and how?
And what are the ways to get this done?
Should I install a font somewhere?
Should I use webfonts (like google webfonts)?
What is the advantage in using this?
or what are the other ways?
Smith Brown
Re: Changing Fonts (and related settings ) In Wordpress
on Nov 8, 2011 at 10:40:33 am
I am also not knowing about this .
Will u please tell any one for this issue ???
Smith brown
convert FLV to MP4 | convert FLV to MOV
Fernando Mol
on Nov 8, 2011 at 4:00:22 pm
Wordpress has their fonts defined in external CSS. If I remember well the file should be called Styles.css
If you are not familiar with CSS you can end messing up the whole site. So I recommend to backup before you play.
I hope this helps
