onmouseover question
COW Forums : Web Design
Steve Sommer
on Jul 23, 2011 at 5:06:09 pm
I'm creating a website for my wife and I'm stuck on a mouseover problem. I currently have the page setup to change a large picture when moving over a thumbnail. What I need to do is change a text description next to the larger pic as well.
You can see what I mean at:
Any advice would be greatly appreciated.
Curtis Thompson
Re: onmouseover question
on Jul 23, 2011 at 7:02:37 pm
well - assuming the text is plain html text and not an image, you have a few options:
1. make a javascript array of the text and then add a function to also swap that text out to the desired bit on mouseover (by setting the innerhtml property of the div/span where the text is)
2. make a series of divs (each with the desired text) and then stack them via z-index where you want the text to show and turn on/off the desired one via its visibility property
then for either option, you could just add another function to the mouseover bit - like this:
if none of this is making any sense i could do a mockup of what i mean...
© 2018 All Rights Reserved
