Flash Dynamic Text Problem
COW Forums : Web Design
Kathy Summers
on Jun 4, 2010 at 11:03:51 pm
I am having a problem with the dynamic text on a site I am designing.
I am not a proficient Action Script coder, so this may be a simple solution.
The text is meant to look as though it is typewritten, with each letter appearing separately. This part works fine. The text box should then disappear, however, and I can't get that to work. Any ideas on how to do this? I tried using motion tweens and adjusting the alpha via the timeline, but I had horrible results and all I had was flickering text. I think I just need a little bit more Action Script code.
I am using AS3.
Here is the code:
var str:String = '"jennifer brings exactly the kind of personal warmth and professionalism that is ideal for that special day." -cynthia bartley, mother of the bride';
var i:uint = 0;
var timer:Timer = new Timer(40);
function gotime(e:TimerEvent) {
if(i>=str.length) {
Any help is greatly appreciated. Thanks.
Fernando Mol
Re: Flash Dynamic Text Problem
on Jun 6, 2010 at 3:29:04 pm
Actionscript is the programming language for Flash. You may get better advice for this question on the Flash forum.
I have achieved the effect you're mentioning, but not using Actionscript, also, not with dynamic text. Just plain animation using masks and fades.
*Always share a link to your site and rate the posts. This is a free service for you and for us.
Kathy Summers
on Jun 8, 2010 at 3:59:56 pm
Thanks Fernando. I will try there.
© 2018 All Rights Reserved
