Simplifing the Web Design Process
COW Forums : Web Design (Wordpress, Joomla, etc.)
Amy Martin
on Feb 2, 2009 at 3:19:21 pm
Currently I am publishing newsletters on the web for my employer, and I feel like there is a better more efficient process out there rather than the one that I am using. Any opinions would be greatly appreciated.
Right now, I design the newsletter in Publisher, and print to get the pdf version. Then I take the text and format at into Dreamweaver to put it on the web. Then I take the text and format into PHP to send the newsletter out.
I guess the problem I have come across most often is that I have to take the text back to a notepad everytime because the formating between programs doesnt seem to talk.
In college I used a mac with Dreamweaver and I remember it being efficient, but not sure if it would be worth the cost to buy a new computer or a new program.
Like I said any opinions would be appreciated.
Thank you.
Fernando Mol
Re: Simplifing the Web Design Process
on Feb 2, 2009 at 8:04:33 pm
Why are you making a PDF?
I used to send mail invitations for an art gallery. Here is a look at the process I used to do. I hope this can help.
1.They make a design for print.
2.I receive a PDF version.
3.Made an HTML adaptation in Dreamweaver.
4.Upload the images to a server.
5.Fix the links to the images, if needed.
6.Insert the HTML into Outlook.
7.Send the email.
8.Pray for the users to have their "view HTML content" option selected.
Mike Smith
Re: Simplifying the Web Design Process
on Feb 5, 2009 at 4:54:24 pm
Why couldn't you use the html as formatted in dreamweaver in your php - maybe using an echo - three left angle brackets - EOT type construction ?
Mike Smith
on Feb 6, 2009 at 11:22:07 am
Or even try a direct include - pull the html into a php variable and echo it, using something like
ob_start();
include('file.php');
$content = ob_get_clean();
from
http://www.codingforums.com/archive/index.php/t-124537.html
or
ob_start(); // start buffer
include ("file-to-include.php");
$content = ob_get_contents(); // assign buffer contents to variable
ob_end_clean(); // end buffer and remove buffer contents
echo $content;
from
http://www.acuras.co.uk/articles/88-php-include-a-file-and-store-contents-t...
