Simple answer?
COW Forums : Web Design
Rony Kimball
Simple answer?
on Aug 14, 2008 at 4:00:04 pm
I just took over maintenance on a simple html website and the client wants the song he has playing on his home page to play continuously as you navigate the site. Is there a simple code based way to pull this off or will it have to load from each individual page?
Curtis Thompson
Re: Simple answer?
on Aug 14, 2008 at 4:36:13 pm
ooh - to have it continually playing as a user navigates around, you have to have either flash doing the entire site or frames (so a hidden frame has the song and the site is in another frame - then as you navigate around the site in the one frame, the other frame plays the song...
i can't say that, however, w/o noting that frames are typically considered a no-no:
and i'm also not so sure that you want music - it's also sort of considered impolite to do to users, but i'll leave that up to you and your client... :-)
hope that helps!
© 2018 All Rights Reserved
