CSS/HTML Errors
COW Forums : Web Design (Wordpress, Joomla, etc.)
Jeff Kelley
CSS/HTML Errors
on Jul 7, 2008 at 12:58:47 pm
Hello,
I'm correcting all the errors that I've got at a HTML Validation site. This is one I can't figure out. Can you Help?
Jeff
Jeff
http://www.willinois.com
Curtis Thompson
Re: CSS/HTML Errors
on Jul 7, 2008 at 5:03:41 pm
hello...
i'd try dropping the space between the "=" and the next quote for the first one - and wrt type - you need to add text/javascript if you want to be in full compliance...
http://www.w3schools.com/TAGS/tag_script.asp
hope that helps!
sitruc
Jeff Kelley
Re: CSS/HTML Errors
on Jul 7, 2008 at 5:08:02 pm
Thanks Curtis,
A big help, as always. One more, how about this?
Error Line 357, Column 7: XML Parsing Error: Premature end of data in tag body line 23.
Jeff
Curtis Thompson
Re: CSS/HTML Errors
on Jul 7, 2008 at 5:09:36 pm
hello...
ooh - this one is pretty much impossible to say w/o seeing code... :-/
note too that none of these are bad per se - if you are trying to be very strict and correct with your html then they are good to fix, but they won't impact much else...
sitruc
Jeff Kelley
Re: CSS/HTML Errors
on Jul 7, 2008 at 5:17:08 pm
Thanks. I won't embarrass myself or bore you with coping my code. Thanks for all your help. Probably have some more soon!
Jeff
Sapphire Parker
Re: CSS/HTML Errors
on Jul 31, 2008 at 2:02:57 pm
Replace your script tag with this one
