Dreamweaver (Embedded mpegs and Flash Text)
COW Forums : Web Design
Joe Colombatto
on Jun 2, 2008 at 8:39:13 pm
I successfully embedded an mpeg file into an html document, and even set the parameter for
Autoplay/False (which turns the autoplay off). Because I have multiple videos on a page I don't
want them all starting at once.
So now a viewer has to click the little ON button on the mpeg control window to play the movie.
What I wanted to do is have Flash Text that turns on that embedded movie,
(The Flash Text reading something like: PLAY THIS MOVIE) so it's user friendly,
and plays on the same doc page without going to a separate page.
How do I combine these two elements of an instructive Flash Text, with an embedded mpeg
plug in?
Thanks again.
Sapphire Parker
Re: Dreamweaver (Embedded mpegs and Flash Text)
on Aug 1, 2008 at 11:08:00 am
mpeg files cant be played on flash player directly.First we need to manually convert all mpeg files to *.flv file then only we can use them with flash player.
Cheers,
Sapphire
http://www.videoediting-direct.co.uk
