Create an animated banner in AfterFX
COW Forums : Web Design
Leonard Koch
on Jan 12, 2008 at 1:02:31 pm
Hi Cows
I would like to ask you a tiny little Question that's going around in my Head for some time.
Is there a way to create a banner like on this site for example: ?
I tried the animated Gif Render but it doesn't look as good as I want it, so I'm asking you is there a different way to create such thing or at least a possibility to make the Gifthingy looking good?
I'm looking forward to your Help.
Abraham Chaffin
Re: Create an animated banner in AfterFX
on Jan 15, 2008 at 6:52:57 pm
Most animated banners on the net now are made in Flash. You can create these sort of banners using After Effects export to flash video feature which makes it so you really don't need the Flash application as it even will create the HTML file for you.
Check out this tutorial on creating Flash Videos for the Web Using After Effects and other programs in....
© 2018 All Rights Reserved
