COW Forums : Web Design
mark cookman
on May 10, 2005 at 1:50:03 pm
Thanks for the learning pointers you gave me recently. I want to use the client_area script you offered .
I have followed the install thoroughly but get a "too many redirects" when I login.
This script will be great ..... I'm clucking for it!
Curtis Thompson
Re: script
on May 10, 2005 at 3:46:38 pm
unfortunately i don't/can't (due to time limitations) offer technical support for it - but that sort of message would tell me that you might have something wrong in your config area, and the result is that the browser is ending up in a redirect loop - so for example, you are accessing a page and it fails a session and tries to go to a login page, but the login page is redirecting back to that page (or something like that)...
without knowing your setup, seeing the conf file and knowing your browser, etc. and what other debugging you've done (i.e. does this happen in all browsers, platforms, etc.) then it's hard to say - and if i knew that, i'd be doing tech support... :-)
so the best thing i can offer is to double-check your config parameters and maybe try installing again...
(sorry - i wrote that as a one-off a long time ago for someone else here on the cow and i make it available, but i'm too busy to really support it very much...but if you want to post a link to a zip of your conf file (sans any sensitive data in it) then i can glance at it at some point for you and see if anything sticks out)
© 2018 All Rights Reserved
