Suggested Setup on Raided Drive
COW Forums : Autodesk Smoke
Daniel Burrell
on Dec 14, 2015 at 2:52:00 pm
I just upgraded to a new Mac Pro with raidable Thunderbolt storage. All of our media is backed up archive drives, so there is no need to use raided storage for that, but if possible I would like to store projects on a raided partition if that's possible, so those are protected in the event of a drive failure.
Is it possible to set up Smoke so that projects are stored in a separate location from renders/media storage? All I see in Smoke Setup is the ability to add media storage, but not to denote what goes where.
moody glasgow
Re: Suggested Setup on Raided Drive
on Dec 14, 2015 at 4:51:54 pm
I don't believe that is possible.
But, did you know that the project info is stored in /usr/discreet/project/
Also, I would highly recommend that you use RAID 5 or better for your media. Drives fail. And they like to fail at the worst possible time.
moody glasgow
vfx superisor / flame artist
jackalopefx.com
Daniel Burrell
on Dec 15, 2015 at 7:49:12 pm
What utility do you use for your raid 5 setup? We've got a OWC Thunderbay 4 that I am currently in the process of setting up. I can't do raid 5 with Disk Utility. Also, it is my understanding that if I do a raid 5 setup, it will cut my storage in half, which means that with 20TB worth of storage in there, doing a raid 5 setup will cut that down to 10TB. Is that correct?
Joel Osis
on Dec 15, 2015 at 10:26:23 pm
raid 5 doesnt cut ur storage in half u will loose aproximately 5tb so 15tb usable
w: http://www.joelosis.com
e info@joelosis.com
Walter Soyka
on Dec 16, 2015 at 1:35:17 am
Thunderbay doesn't have a RAID controller, right? Have you tried SoftRAID?
Walter Soyka
