Burn In Timecode node not behaving as expected
COW Forums : Autodesk Smoke
Alan Okey
on Oct 29, 2015 at 9:19:46 pm
In Smoke 2016, I'm prepping RED footage stringouts for an offline edit by adding a Burn In Timecode node to each clip in the sequence via ConnectFX. Source footage was shot at 6K on a RED Dragon at true 24p, with time-of-day timecode. Smoke soft import setting is 1/4 debayer.
In the Burn In Timecode node parameters, I'm selecting Source Timecode, but the timecode remains set to 00:00:00+00, and the option to get timecode from the clip is greyed out. I have to manually enter the starting frame source timecode by copying the Media In timecode from the media browser.
Am I doing something wrong, or am I misunderstanding how the node works?
Grant Kay
Re: Burn In Timecode node not behaving as expected
on Nov 2, 2015 at 2:05:06 pm
Hi Alan,
I have seen it on my software as well.
I have raised it to the team and they are aware of the issue.
Apologies for the inconvenience.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Alan Okey
on Nov 2, 2015 at 2:25:28 pm
Thank you, Grant.
