Stabilize vertical only
COW Forums : Autodesk Smoke
Daniel Burrell
on Jul 7, 2015 at 1:51:08 am
I have a dolly shot that has some vertical jitter. I am using the stabilizer in the 2d transform timeline effect to stabilize the shot, but it is trying to track the shot horizontally as well as vertically. Is there a way to only stabilize the y-axis? I have selected the "remove vertical jitter" option in the editor, hoping that would limit it to vertical adjustment only, but that didn't help. So how would I go about limiting the stabilizer to only stabilizing vertically and not horizontally? Thanks.
Bob Root
Re: Stabilize vertical only
on Jul 8, 2015 at 7:59:24 pm
Hi Daniel,
You may have solved this already. If not...
After entering the stabilizer hit the return button to take you back to the 2d transform menu.
You'll see a position-x and position-y option now (for some reason they aren't active buttons unless you've already entered the stabilizer). Toggle on and off for your stabilizing axis and re-enter the stabilizer to analyze.
Hope this works for you.
© 2018 All Rights Reserved
