exporting 3d camera track from smoke
COW Forums : Autodesk Smoke
al ellis
on May 4, 2015 at 11:49:50 pm
Hi, Just wondering whether anyone's having consistent results in exporting a camera track to 3ds max? followed what little tutorials there are but to no avail...ah well, back to syntheyes i guess.
Grant Kay
Re: exporting 3d camera track from smoke
on May 6, 2015 at 9:13:19 am
The FBX camera export supports the camera and any axis points you create. You can choose these options in the export menu.
The FBX export does not support geometry, only camera metadata and axis (pointers/locators/helpers.)
This should actually be a pretty straight forward process.
The only issue that you may encounter is units of measurement in 3DSMax since Action only supports pixels but you can specific the units in 3DSMax.
Hope this helps.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
